Ionity charges only with 37kW @SoC 61%
IONITY France Aire Vallee de la vire gouvets
IONITY Charging Station
+33 1 87 21 08 91
https://maps.app.goo.gl/BpAoQhQrwbo2A1mW9?g_st=ic
Polestar PS 2 SMLR
connected at SoC 61%
loads only with max 37kW
any idea why so slow?
Did you have the HPC as destination in Google Maps?
Why did you start charging at 61%? Thats almost full (for long distances).
Did you try another charger? Sometimes the HPCs limit power if they are overheating or if the grid is limited at the moment.
thanks for your information
Indeed HPC was not in Google.
We decided spontaneous to have a break at the station and I decided to use the time for charging
Try to follow your suggestions next time
The battery was pretty full… and maybe even a tiny bit too cold. But generally speaking there could have also been something wrong with that particular charger.
I was charging at a supermarket the other week… and it was supposed to give (I think it was) 150 kW… shared between the 2 ports, so max 75 kW with two cars charging. Instead… I was only getting around 25 kW. When the other car left it went up to around 50 kW.
So there’s no need to worry…
